I had an avi downloaded from the net, and I used tmpeg to convert it to mpeg. When i try to author it using ulead, it says it is not a compliant mpeg file. what is the problem?
Results 1 to 9 of 9
we need more info !!!
what exactly did you do ?
did you use the right templete or not?
reasons could be - bitrate,resolution,and audio.
check if they are complient to the standart or not.HELL AINT A BAD PLACE TO BE -
At the main screen after I click author dvd, when I click add mpeg file, it says the file is not mpeg compliant. So I cant change the settings or anything. I dont get that far.
im not talking about ulead, im talking about what did you do
when you used tmpeg.
maybe you didnt use the right templete in tmpeg,
and thats why ulead is saying that the file is not compliant.HELL AINT A BAD PLACE TO BE -
ok, i will make a quick guide for you.
movies come with different framerates(fps)
ntsc = 29.97 (fps)
ntsc film = 23.97 (fps)
pal = 25 (fps)
first, you need to know what is the framerate of the avi.
you can find out by right clicking on the avi and selecting properties.
after you find out the framerate, you need to convert the avi to mpeg
using tmpeg.
run tmpeg, load the avi, and load the templete you need
(its probably ntsc), and convert the avi to mpeg.
now, you have an mpeg file that you want to load to ulead.
run ulead, and again select ntsc or pal (if i remember it right, you can change it under project properties)
make shoure that you select the same as you selected
in tmpeg (ntsc or pal).
and thats it, i dont think you will have any problems.
or in short :
if its pal, go with pal on both programs
if its ntsc, go with ntsc on both programsHELL AINT A BAD PLACE TO BE -
Make sure that the box "do not convert compliant files" is ticked or Ulead will change it into an out of synch pixelated piece of crap.
In the help section of Ulead is a description of compliant DVD parameters. Make sure your video conforms to one of them. Also when you start up Ulead make sure you choose the proper format for authoring/burning (PAL or NTSC).
And if worse comes to worse, you can always smack head into wall for using a Ulead product. I know I have on countless occasions.
Problem with Ulead Videostudio SE DVD and EasyCAP
By Majora in forum Capturing and VCRReplies: 17Last Post: 20th Nov 2011, 03:51 -
Sound problem with Ulead VideoStudio 11
By rogerhacker in forum Newbie / General discussionsReplies: 15Last Post: 16th Jul 2010, 19:41 -
dv/ulead capture, aspect ratio problem
By Statick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th Jan 2008, 15:46 -
Ulead VS10 sound problem
By theguy1991 in forum EditingReplies: 1Last Post: 3rd Dec 2007, 19:06 -
Truncation problem when burning DVD using Ulead VideoStudio 8
By goodneit in forum Authoring (DVD)Replies: 3Last Post: 9th Jun 2007, 10:23
