I've converted an AVI-file to MPG with TMPGEnc where the audio of the source file was fine and the the destination MPG was fine too when I played it on my computer. However when I play on my DVD-player (Pioneer 636D) the audio is noticably worse. Loud parts are distorted almost like the bitrate is too low but it isn't. Any idea what might cause this and how to fix it?
this is due to the sound encoder not being so good. but the worst part is that there seems to be a lack of a frequency resampler in tmpgenc, I use external plugins.ie if the source is not 44.1khz it can sound really bad.
frequency resampler - scmpx
sound encoding - toolame or scmpx -
This does help. I ususally just use scmpx in the "Sampling frequency convertor" under "evironmental tools" on the "external tool" tab in tmpgenc.
Here is the link to get SCMPX.
http://www.din.or.jp/~ch3/index_e.html
Actual exe: http://www.din.or.jp/~ch3/smxwin151e.zip
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Fixing bad resampled DVD audio
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 10:59 -
nero with bad audio quality?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 1Last Post: 3rd Sep 2007, 04:07 -
bad audio frame
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2007, 14:37 -
Bad Audio problems
By Shaba1 in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2007, 00:02
