Hi,
I'm new to burning VCD's for the purpose of watching them in my DVD player but definetly not a newbie in terms of problems, I think this question will be easy for someone to help me with so here goes:
What I'm wondering is what matters when you are burning the VCD. Im trying to fit a season's worth of episodes onto as few cd's as possible while keeping the best quality. All of the episodes are roughly 400mb(pre-encoding), and 50 minutes in length. So when encoded I would expect each episode to go down to about 200-300mb and obviously retain the 50 minute time. Finally, what I am asking is, does this mean that i can fit almost 3 episodes on 1 700mb cd (2??mb x 3) or does it go by time and I will be only able to fit 1 and a bit on a 80min cd.
Thanks!
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
if your going to follow the exact VCD standards then 80 minutes is max per disc or up to 82 minutes w/ overburn. if you lower your bitrate you can get more than 80 minutes per episode. use a bitrate calculator if you want to do this.
Hi
i know ur prob man
U can use mode2 its simple!
It burns your avi files like vcd/svcd
Because of that you will get 795mb instead of 700mb
The only thing u need to read those files directly is mode2filter
It would'nt slow down ur cpu.
Im not sure exactly where u could get it
Just search for mode2cdmaker or contact me at zeven_christ@hotmail.com
The only minus with this is that u must have this filter to read it directly.
That means if u want to watch the movies on ur friends pc he must install the filter -
So the answer is, it goes by time ? Like an audio cd, 80 minutes is max.
Correct? I'm not really interested in fiddling with things too much, I just want to know if it goes by time or by size, and from what these 2 replies say I'm thinking its going by time.
Thank You!
auto fit
By roystheboy in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2008, 05:23 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 11:46 -
subtitle that doesn't fit
By Belfour in forum SubtitleReplies: 5Last Post: 14th Aug 2007, 08:30 -
Help to fit two DVDs into 1
By heretic1 in forum Authoring (DVD)Replies: 1Last Post: 12th Jun 2007, 22:57 -
What Is The Best Way To Fit 2 Hours On A DVD?
By Anakin in forum Video ConversionReplies: 14Last Post: 4th Jun 2007, 11:52
