I have a problem with the video being too bright on my DVD player but the original file on my computer is fine. I encode with Tmpegenc, not deinterlaced, with high quality settings (soften block noise, and little tricks suggested on this site from guides). I have toyed with the simple color correction, but I am unsure of what the settings do there. Does anyone know if I'm doing something wrong, or can direct me to a guide describing the simple color correction tool?
Video captured from a analog source like a TV or VCR will always appear dark on your computer monitor. Color and brightness correction is only needed for when you are using the video for computer use... otherwise when played on a tv it will be to bright...
under the quantize tab-> special settings -> UNcheck "output YUV data as basic ....."
Tv's are 16-235 , pc monitors are 0-255 ,
this is known as "clamping" 255 on a tv would be to bright , conversly 16 as black on a pc will look washed out a bit but appear as black on TV ..
broadcast NTSC is always clamped to these specs .. -
if you need to - you can ->custom color correction - add YUV -> clip low/high -> set high to 235
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 06:39 -
= bright and dark
By beetlespin in forum EditingReplies: 6Last Post: 16th Aug 2010, 19:38 -
Newbie Frustrations - VHS to DVD or Comp Help
By BrianJ844 in forum Newbie / General discussionsReplies: 11Last Post: 3rd Aug 2010, 12:01 -
Making a comp. DVD with DVD-Lab Pro..
By Superstar24 in forum Authoring (DVD)Replies: 1Last Post: 26th Jul 2009, 19:24 -
Creating a Comp DvD problems
By JKG in forum Authoring (DVD)Replies: 1Last Post: 27th May 2007, 05:15
