Hi, this is my first post here,
two week ago, i' ve bought a sony dru500 ax, then i 've tried to burn the dvd +rw, selled with it with the last version of nero the 5.5.10.28, and it works fine.
Then later, i've bought some Verbatim dvd-r and it works fine too, instead some days ago i had bought some that's write 4x ""certified"", and the result it' s a little disaster.
Because, when the burning process starts, then line of progress is blocked at 1%, and after 2 or 3 minutes, Nero show me this message:
No seek complete, burning failed......and the dvd-r is lost....![]()
Well i've wrote to Sony, and they told me, to use the software gived with the dru500ax, so yesterday i tried this way, using the RecordNow of Veritas, something appened, because the line of progress shows me a nice 9%, but at this point, another terrific message appear......burning process failed...error, put another disk into the drive.......what?!?!![]()
If anyone of you has suggestion for me, it will be very appreciated...
thanks..
STOP TRASHING THE WORLD....AND THE UNIVERSE
pleaseeeeeeeeeeeeeeeeeeeeee helppppppppppppppppppp meeeeeeeeeeeeeeeeeeee!!!!!!!!!!
nooooooooooooooooooooooo!!!!!!!!!!!!!!
muueeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!STOP TRASHING THE WORLD....AND THE UNIVERSE -
Do not use NERO...use RecordNow DX that came with the drive instead.
Actually it could be that you have to update your firmware.
I had huge problems when I used NERO so I tried RecordNow instead and have not had any problems since then, I have burned the following media:
Infinity DVD-R printable
Infinity DVD+R silvertop
Verbatim DVD+R silvertop
Verbatim DVD-R (2x) printable
Ritek DVD+R Printable
Princo DVD-R (2x)
Verbatim DVD+RW
Sony DVD+RW
Ricoh DVD+RW
PrimeDisc DVD+RW
The ones that did not work in NERO was Verabtim DVD+R and Princo DVD-R, both of these worked just fine with RecordNow DX. As you can see have I not burned any 4x media yet so it might be that I run in to problems with RecordNow DX when I do get around to burn some.
By the way I use Firmware 2.0c.
Error message on Sony Camcorder
By bhomis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Jul 2009, 17:46 -
Sony Vegas 8 error
By connect in forum Newbie / General discussionsReplies: 4Last Post: 25th May 2008, 19:17 -
Seek Failed
By zeke1312 in forum Video ConversionReplies: 1Last Post: 20th Mar 2008, 07:59 -
nero - dvd burn failure - no seek complete error
By rock in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 15:28 -
"can't seek backward" error
By perfection in forum Authoring (DVD)Replies: 3Last Post: 10th Jun 2007, 06:23
