Help: vcdeasy v1.13 dois everything ok and makes the image file. But when it goes to burn I get this message:
[CDRDAO Write]
Cdrdao version 1.1.7
ASPI: C:\WINDOWS\System32\WnAspi32.dll
1,0,0: AOPEN CD-RW CRW2440 Rev: 2.08
Using driver: Generic SCSI-3/MMC (raw writing) - Version 2.0 (options 0x0000)
WARNING: Length of toc (88:39:13, 398938 blocks) exceeds capacity of CD-R (79:57:74, 359849 blocks).
WARNING: Ignored because of option '--overburn'.
WARNING: Some drives may fail to record this toc.
Starting write at speed 8...
Using 96 byte raw P-W sub-channel data mode.
Executing power calibration...
cmd finished after 7.021s timeout 20s
ERROR: Power calibration failed.
ERROR: Use option --force to ignore this error.
ERROR: Writing failed.
ERROR: Note that CDRDAO troubles are often related to the use of an inadequate driver...
ERROR: You may have a bad CDRDAO driver in the CDRDAO settings page.
Well, don't know why power calibration falis, but when that's happened to me, I just eject and reinsert the CD-R again, and give it another go.
Besides that, unless you're using a 90 min CD-R, you wont be able to fit 88 min of data.
Last resort is not to use VCDEasy to burn - just create the cue/bin, and use Nero (or some other app that works with your burner and can handle cue/bin) to burn this.
You could also try latest VCDEasy, as it can use Nero to burn.
/Mats
Troubles burning avi to a dvd with nero vision
By falcon1 in forum Authoring (DVD)Replies: 3Last Post: 13th Oct 2008, 11:36 -
Subtitle troubles
By ROOK1E in forum SubtitleReplies: 1Last Post: 1st Aug 2008, 03:48 -
Troubles burning OTA HD to DVD
By mattman1968 in forum DVB / IPTVReplies: 3Last Post: 3rd Jun 2008, 07:41 -
burning troubles on the back end
By beck59 in forum Authoring (DVD)Replies: 1Last Post: 24th Dec 2007, 23:11 -
TV Out Troubles.
By SE14man in forum Newbie / General discussionsReplies: 54Last Post: 11th Oct 2007, 16:55
