I tried burning a vcd through adaptec but the mpeg files get recorded in the segment directory and nothing gets recorded into the mpegav directory
the cd also wont play in a vcd player.
The files get recorded as item***.dat files in the segment directory.
I have adaptec platinum version 5.02.
How can i solve the problem.
Whether they actually are or not, Ez cd creator thinks your mpgs are non-compliant. If you look at its compliance properties some boxes will be in red if they arent compliant. Try demuxing and remuxing in TMPGenc with mpeg1 vcd set to output. (File/Mpeg tools/Simple demultiplex and Simple Multiplex.) This should produce a compliant mpeg assuming it was encoded correctly. This will probably burn ok in ez cd creator but honestly that burning program is terrible, I would use any other software you can find.
get NERO, it makes making XVCDs much more fun. No compliance needed with NERO.
Adaptec AVC-3610 Dual TV Tuner - NEED HELP!
By kookie2000 in forum Capturing and VCRReplies: 13Last Post: 7th Mar 2010, 08:56 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
[SOLVED] Adaptec AHA-2944UW WinXP Driver
By sdsumike619 in forum ComputerReplies: 2Last Post: 20th Oct 2008, 03:05 -
Onboard Raid 5 vs. Adaptec PCIE
By mike909 in forum ComputerReplies: 18Last Post: 2nd Jun 2007, 02:05 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 12:39
