I have a 4 divx files with the following properties:
480x360 resolution
23.976 fps
I don't know if they are interlaced or deinterlaced. I want to convert to dvd using Tmpegenc plus using cbr 3500 as birate for size.
Anyone have any suggestions on
1. What dvd template should I use, PAL or NTSC given the fps of the source file or does it matter, I am using a NTSC tv as I am in the U.S.
2. Whether to deinterlace or interlace encode? i.e. the advanced options in Tmpegenc.
3. I saw someone post that Tmpegenc has bad default settings under GOP and that I should change them to:
Number of I Pictures =1
Number of P Pictures=4
Number of B Pictures=2
Output Interval of sequence header=1
Max numbers of frames per GOP=18.
Is that right? Any help would be appreciated. BTW I have made many dvd's before, but not with divx files so I am fairly familiar with the process.
Use the NTSC template, leave it in interlace mode, unless you plan to watch it on your computer. Finally, encode only a sample of your video ( a few minutes of it should do) to a DVD-RW, until you get the settings to give you the product you want, then burn in entirety with a DVD-R.
Hello.
5.1 Hi-Fi Suggestions?
By therock003 in forum AudioReplies: 11Last Post: 8th Dec 2011, 12:19 -
Any suggestions for this mp4?
By nick_unbc in forum Video ConversionReplies: 9Last Post: 4th Oct 2008, 21:57 -
new PC suggestions
By kj1983 in forum ComputerReplies: 9Last Post: 18th Aug 2008, 17:45 -
program suggestions
By Kibble in forum DVD RippingReplies: 15Last Post: 7th Mar 2008, 16:52 -
I need suggestions
By aruwin in forum EditingReplies: 3Last Post: 18th Nov 2007, 05:23
