Does anyone know if it is possible to assign a different audio track when applied to a different video angle. the manual says it has to be a continuous audio track. Is there any other programs that may be able to do this.
You can use a command sequence that will change the audio when the angle is changed.
If you want a different angle with a different audio stream, isn't that the same a different movie? Why not just create another title set, or even a playlist? -
I have found command sequences quite confusing I thought that you would be able to do it that way but was hoping for an easier way...guess it is back to the manual time again.
Multi-Angle DVDs... and Blu-Ray?
By blazin-j in forum Newbie / General discussionsReplies: 11Last Post: 12th Oct 2010, 11:40 -
Backup a multi angle DVD
By src2206 in forum DVD RippingReplies: 1Last Post: 9th May 2009, 00:34 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 20:44 -
How to add subtitles to a Multi-Angle DVD?
By cruel! in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 01:10 -
Multi angle - dilemma
By flipzoso in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 02:36
