Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I have been thru the entire process but I cant get TMPG to save my files after I cut them to make room for 2 discs. When I hit save, it just doesent do anything. Anyone know what the problem is?
    May 2001
    London, UK - Bonn, Germany
    Do you press "run" in TMPGEnc Merge/cut?
  3. Well, that was part of my problem...whoops..dont know how I missed that one =) Now, evertime I hit run, it runs for a little while, then says Stream Copy Error???
    May 2001
    Check that
    a) you have enough disk space (about twice the size of the finished mpeg)
    b) your hard drive is formated
    If you have done this and the feed is still corrupted try using the mpeg corrector, downloadable in the tools section.
