i was saving a movie through virtualdub and used the divx compressor. now when i opened it in tmpgenc there is no video. do i need some sort of codec. i already have the divx 5.05 codec. maybe i just used the wrong compressor in virtualdub. any thoughts on what might have went wrong??
Possibly some bad encoding which causes TMPGEnc to be unable to open it, you can however try increasing the AVI Multimedia reader in TMPGEnc, and it may fix your problem, if not, you can always use VirtualDub to frameserve
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
im pretty sure it might have either be that i need some sort of codec or i should have used a different compressor in virtual dub. im able to oopen it with anything except for that there is no video, just audio.
just forget wat i said above. ive never tried frameserving before. i thought it wud be hard but the funny thing is that i learned how to do it in 10 seconds. thanks for the advice. im sure itll work and save me a lot of time.
I'm Glad to be of help!
Best Regards,
Sefy Levy,
VirtualDub Video Compression h264 encoder Not Shown
By darkw1zard in forum EditingReplies: 2Last Post: 18th Oct 2011, 14:28 -
Help? No size is shown for video or audio file.
By thezanny in forum Video ConversionReplies: 5Last Post: 10th May 2011, 04:28 -
is 1080p shown in Height in mediainfo?
By justravis in forum Newbie / General discussionsReplies: 8Last Post: 24th Feb 2011, 17:48 -
X264 GUI Shown On The Tutorial
By Cunhambebe in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2008, 21:11 -
How To Encrypt a video so it will not be shown on streaming video site
By doggieusa in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2007, 08:22
