Is there S/W I can use to capture streaming RealVideo
from a web site to a file?
Thanks,
Mike
Hm.. that's kinda tricky. I don't know much about RealNetworks' format, but here's what I do know...
Try saving the RA/RAM file to the hard drive. Check the file size of that file, if it's a mere few kilobytes, then it's only a redirection file. Open that file with notepad. There should be a link toward the real source. Download *that* file. And hopefully you got yourself the video you wanted. =) -
also "RealProducer Plus" can be used to get the movie from a URL location (Not protected)
Search for StreamBox VCR 1.0 BETA 3.1 to "capture" the .rm files. I've also used Tinra to convert from .rm to AVI. I've only used StreamBox a couple of times, but it worked flawlessly.
Capture audio from web stream ?
By Zetti in forum Capturing and VCRReplies: 2Last Post: 12th Dec 2011, 17:20 -
Capture flash video playing in a web browser?
By sdsumike619 in forum Capturing and VCRReplies: 2Last Post: 14th Nov 2010, 00:28 -
Capture game play on the PC and make it available on the web
By gamerscircle in forum Newbie / General discussionsReplies: 4Last Post: 11th Dec 2008, 18:15 -
Any gurus here that know how to capture SWF from the web?
By sdsumike619 in forum Newbie / General discussionsReplies: 18Last Post: 6th Feb 2008, 21:53 -
how can I capture video from the web
By brew in forum Newbie / General discussionsReplies: 1Last Post: 19th Nov 2007, 22:52
