Hi to all on the group.
Eric here.
My question is as follows,
Having used decriptor to rip a dvd to my hdd I would like to be able to use the crop facility that dvdshrink offers me and then be able to reincode the movie with dvd2one. but because dvd shrink encodes the files - dvd2one cannot then encode them as the files need to be riped on the hdd for dvd2one to use them.
i.e.
I can using dvdshrink, pick the main movie and a sound track and then crop the end credits off the movie sometimes saving 200 to 250 mb of space. the resulting files contain only the main movie with no credits. For example say the main movie was 5.0gb in size after using dvdshrink I would be left with a movie file size of say 4.4gb in size. just over whats allowed.
Now as you can see the 4.4gb file would need less encoding (loss of quality) in dvd2one. I could of course use shrink to compress and encode it but its very inflexable and the minium 20% or so of compression is more than is required and you cant just tell it you want the movie to end up being exactly 4.38gb in size unlike with dvd2one.
Using dvdshrink to compress the 4.6gb would leave you with files of roughly 3.68gb which is a lot of wasted disk space and a lot of needlessly compressed video footage.
So is there any way I can get pick the main movie, pick an audio track getrid of subtitles & get rid of the credits and then have it on the hdd in a compatabe form so that dvd2one can read the files.
would i have to use info edit and if so how would it be able to be done.
thanks in advance.
Eric
I don't see why DVD2ONE will have any problems accepting the DVDShrink Input files as source. They should work for DVD2ONE. If they don't work... Try DVDToolBox... maybe that'll help.
dhluke
DVD Ripping...DVDShrink, DVD Fab question...
By nharikrishna in forum DVD RippingReplies: 9Last Post: 28th Feb 2011, 05:08 -
Question about DVDshrink and lossless copying
By sasuweh in forum Authoring (DVD)Replies: 5Last Post: 5th Oct 2010, 13:08 -
DvdShrink question?
By Loader09 in forum DVD RippingReplies: 2Last Post: 13th Nov 2009, 12:10 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
dvdshrink question...
By cyane30 in forum Newbie / General discussionsReplies: 6Last Post: 1st Nov 2007, 14:14
