Hi, I have received the 7 season of Star Trek in avi, and would like to put them onto a dvd-r..
What is the best way to do that, and without losing the quality of the avi clip???
Hope somebody can help??
You don't say which software you have available, but the fastest and easiest method would be to use Quicktime Pro to convert the AVI's to DV (depending on the AVI's codec, this may require using the Classic version of QT), and then iMovie/iDVD to make the DVD.
Without those, your best bet is probably MediaPipe and Sizzle, but you might still need QuickTime's help to get the AVI to a format that Mediapipe "likes."
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
