Hi there,
I have a PAL JVC Camcorder and am hooking it up to an NTSC TV. Whenever I playback, it comes out in black and white. Any ideas of how to get around this?
Ivxample![]()
No problem. You have to open up you TV and move the Color sub carrier frequency. Do you have the schematics of your TV? You going to have to order a part probably, but you might be able to re-program the PIC. On a side note, if you are going to deal with RF, most PAL channels have a 6 Mhz audio subcarrier instead of the 4.5 Mhz in the US.
You can't do it, that's why there are dual PAL/NTSC TV's avaialble.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Trade the TV in for a multisystem, or the camera in for an NTSC model. You may also put the video into a computer, convert it to NTSC, put it into an (S)VCD or DVD disk and play it on a compatible DVD player. Other than that, there is no way I know of to make a PAL camcorder video play on an NTSC TV.
Hello.
Captured video is in black and white (NTSC vs PAL problem?)
By Helena in forum Capturing and VCRReplies: 27Last Post: 18th Apr 2023, 19:34 -
PAL Capture Black & White
By SGGS in forum Capturing and VCRReplies: 42Last Post: 9th Dec 2011, 05:12 -
Black and White (NTSC-U\ NTSC-J) !
By Somi in forum Capturing and VCRReplies: 0Last Post: 25th Mar 2009, 06:57 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 13:37 -
Capturing NTSC VHS becomes black and white !
By gneseew in forum Capturing and VCRReplies: 11Last Post: 19th Mar 2008, 20:09
