I have a series of MPEG-1 files I am authoring to a DVD using the new TMPEG DVD authoring program. The files were all created using TMPEG encoder a few months ago. And recreating the file from scratch is not an option. The file is about 4 minutes long but mediaplayer, etc only recognize the first 21 seconds. I believe this is a problem with TMPEG. When you encode and abort a project and start again the program usually gets corrupt. This happens when you use the same filename but choose to replace it. For some reason it uses the original timecode for the new file you will create. I remember this happening when I created the file. But I never worried about it because it plays fine in my DVD player. Now I want to convert it to a DVD but that file always messes up. Can anyone tell me how to fix the "timing" problem?
Russell
Results 1 to 1 of 1
A corrupt file after sending a .3gp file via bluetooth
By ViDector in forum Video ConversionReplies: 3Last Post: 15th Aug 2011, 09:03 -
Corrupt File Needs Fixing, PLZZZ
By kame1986 in forum Newbie / General discussionsReplies: 3Last Post: 6th Apr 2011, 02:51 -
Fixing / hex editing a corrupt MP4 - paid work?
By geefin in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2011, 03:19 -
Fixing a *corrupt* mov/H.264 video
By urymf in forum Newbie / General discussionsReplies: 6Last Post: 10th Dec 2010, 05:34 -
Corrupt MPEG1 file plays nothing but blue
By croix19 in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2007, 02:28
