I have a series of MPEG-1 files I am authoring to a DVD using the new TMPEG DVD authoring program. The files were all created using TMPEG encoder a few months ago. And recreating the file from scratch is not an option. The file is about 4 minutes long but mediaplayer, etc only recognize the first 21 seconds. I believe this is a problem with TMPEG. When you encode and abort a project and start again the program usually gets corrupt. This happens when you use the same filename but choose to replace it. For some reason it uses the original timecode for the new file you will create. I remember this happening when I created the file. But I never worried about it because it plays fine in my DVD player. Now I want to convert it to a DVD but that file always messes up. Can anyone tell me how to fix the "timing" problem?
Russell
Results 1 to 1 of 1
Fixing bad resampled DVD audio
By silverwolf0 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2009, 11:59 -
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 07:30 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 17:19 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 01:21 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 05:31
