Hi
I have an xvid avi, which I'm trying to rip to svcd.
Its audio is 48Khz Fraunhofer IIS MPEG Layer-3 Codec, which I believe is MP3, right?
I did the following:
1) VDub 'Direct Stream Copy' to a 110 Meg '.wav' file
2) rename '.wav' file to .mp3
3) Did a CDex 'Convert compressed audio file to wav file" --> gives me a 1 gig audio wav file. Checked it in WinAmp, and it was perfect. Great quality, but still 48khz.
So, when I try and use that in TMPGEnc as the audio source, it works fine and I get a good video result, but the audio is converted to 44khz by TMPGEnc, which makes the audio really 'resonant' - upper frequencies kind of 'echoey'.
So when should I convert to 44khz? At the start with VDub? I looked for it in CDex but it's not there (I think). I'm pretty sure it's TMPGEnc that's causing the sound problems while doing the conversion to 44khz.
I could use SoundForge, but seems like using a steamroller to crack a nut.
Is there a simple step I can do rather than adding another long step to my avi --> svcd conversion method?
Thanks all.
Most of my knowledge of the above came from my other posts in forums here. This site is the greatest.
:P
will
Results 1 to 9 of 9
Does the SSRC (within TMPEnc) automatically work out what the sample rate and SSRC usage syntax shoud be?
No other settings to be defined?
thanks
will -
Yes, that's the beauty of it. Instead of doing your sampling rate conversion manually, in VirtualDub for instance, SSRC in TMPGEnc is fully automated, once you have it set up. You'll see TMPGEnc first create a temporary .wav file, then SSRC kicks in in a DOS window and automatically converts your frequency sampling rate to the 44,100Hz spec called for when you choose (S)VCD as your target format in TMPGEnc. The temporary .wav is eventually automatically deleted. The whole process is automatic and the results sound great.
You mean 44,000 khz for (S)VCD, right?
I've just started doing one and it looks like it's doing it exactly as you say!
Thanks very much for your quick reply.
Gotta love these programmers.......
Wills -
Actually, 44,100 Hz or 44.1 kHz.
The programmer's name is Naoki Shibata, who did a stint at Stanford University.
Final Cut Pro 5/File quality and conversion questions to .avi
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2010, 20:24 -
HD ts conversion... a few questions
By vol_freak in forum Video ConversionReplies: 0Last Post: 23rd Mar 2009, 12:02 -
Video conversion questions
By Peter88 in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2008, 04:38 -
VOB file conversion to AVI...many questions
By tonyclem in forum DVD RippingReplies: 19Last Post: 7th May 2008, 10:39 -
2 conversion questions
By rendez2k in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Jun 2007, 05:35
