    May 2003
    SW England
    Can any one tell me how to do this, I have the vobs off ind 2 ifo files for the two sides.
  2. I did not know how to do this either, all I did was a forum search above and the below was about option six or seven
    https://www.videohelp.com/forum/viewtopic.php?p=493615&highlight=double+sided+dvd#493615
    try searching before making a post
    If it's wet, drink it
    My DVD Collection
    Jan 2003
    Bay Area, CA
    This is by no means a guide, you'll need to know the progs first but here's my routine for 2DVDs on one disc:
    1. Run both movies through DVD Decrypter for rip.
    2. Transcode both movies with DVD2One using 2.1gig custom file size max.
    3. Delete all IFO/BUP files and move both movies to the same folder (only .vob's remain)
    4. Resequence them by renaming the vobs to VTS_1_1, VTS_1_2, VTS_1_3 etc...this is the sequence you would like them to play on the DVD.
    5. Run the "Create IFO" function in IFO edit.
    6. Burn all files with Nero
    Like I said, this isnt a guide but dont waste your time demuxing or re-encoding. This works just the same although it takes a lot of disc space to process. Good luck!
    "Only Users Lose Drugs"
  4. VobEdit and this guide should do it. Be sure to scroll down to the second half of the tutorial.
    http://ifoedit.wh.fr0zen.com/joinclip.html#joindbl
    LTA
  5. http://ifoedit.wh.fr0zen.com/joinclip.html#joindbl
    Then download TMPGEnc DVDAuthor and make a menu for it. PLEASE SEARCH FIRST! This question has been asked sooooo many times.
    "Mustard?! Don't lets be silly now. But lemon, thats different, thats nice." - The Mad Hatter
  6. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    rip side 1 and move the files to a new directory 1
    rip side 2 and move the files to a new directory 2
    rename the files in directory 2 as follows: vts_01_001.vob, _002.vob etc.
    Open vobedit and join the files in directory 2. make sure the VOBID as requested by vobedit is 1 more than the last vobid in the last vob file in directory 1. Rename the vob files output of vobedit as VTS_01_5.vob, 6.vob (assuming 4.vob was the last file in directory 1).
    now run ifoedit and create new ifo files.
    run dvd2one.
