hi i am trying to do long dvd rips to 2 or more cd's with gordian knot 0.28 it all works great but when i want it to fill 2 cd's it ends up only filling 1 1/2 cd's so its wasting about 350mb that could be used for better quality, soon i plan on doing a 4 1/2 hour movie to 3cds and wanna sort this problem out, if anyone could help it would be greatly apreciated
what codec are you useing?
there is a limit on far a codec can do.you may have max out what the codec can do.so raising the bitrate wont make it higher or a bigger file.
it depends on the movie,it may work out on the other dvd.
what are audio format are you useing?
add the ac3,unless you dont like ac3.
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 01:49 -
Problem with Gordian Knot
By eliqush in forum Video ConversionReplies: 3Last Post: 7th Jul 2009, 19:35 -
Major problem loading audio from AVI file into Auto Gordian Knot v 2.45
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 06:12 -
Problem On Encoding DVD to H.264 By Gordian Knot
By bugsboney in forum Video ConversionReplies: 6Last Post: 27th Jul 2008, 09:52 -
Gordian knot sound problem !!
By markos in forum DVD RippingReplies: 3Last Post: 22nd Nov 2007, 03:58
