Hi.
I use TEMPgenc to convert avi to vcd/svcd and I always use the same avi file for audiofile and videofile.
It works most of the time but today I got a straight green "audioline" without any wavew that displays the sound, and when I checked the file it was converted without the sound.
If I open the Avi-file in my power-dvd it works fine with the sound, but I cant convert it...
Do I have to "rip it out" with audiodub or similiar program?
Thanks for any help
Stefan
Scan with gspot check codec of audio, if you do not have it download it. Extract it with virtual dub and then combine with the original in tmpgenc. If the audio is ac3 look here
https://www.videohelp.com/forum/viewtopic.php?p=525099&highlight=#525099
Any probs with the above post back
Hi.
WOW!...this was easy to fix.
Virtualdub was both fast and easy to use.
From now on I will use it on all my films.
Thanks alot
Stefan
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
