Invalid field in parameter is the message I always get everytime i try to burn a vcd on nero 5.5. I deleted adaptec but it still doesnt work. What can I do??
Results 1 to 9 of 9
Mike
Hey!!! I have the EXACT same problem. I been trying to burn a vcd that will play in my dvd player now for the past 3 days!!! I've been trying to use the nero demo 5.5 but always get "Invalid Field in Parameter"!!! After doing some research i came to find out that Adaptec Easy CD (which was preinstalled on my cpu) can't be installed for nero to work. I uninstalled adaptec, located and deleted the adaptec drivers that were left over after the deinstallation, rebooted, installed nero 5.5 and still the same message "Invalid Field in Parameter"... HOW FRUSTRATING!!!! I heard of some utility to switch between adaptec and nero, but i also heard it doesn't work on Windows ME, which is my OS.
I emailed nero about the problem two days ago and have not recieved a response as of yet.
SO, SOMEONE PLEASE HELP ME AND MIKE!!!!!!!!!!!!!!
THX in advance..... -
sounds more like an incompatibility between the burning software and the burner, meaning the burner is not supported by the burning software.
p.s. check with nero to make sure your burner is supported or whether your burner requires a firmware upgrade.
<font size=-1>[ This Message was edited by: hitechjunkie on 2001-09-20 12:09:53 ]</font> -
Hi, I had this exact problem myself. Soon realised that I din not have to audio cable from my cd writer connected to my soundcard. Problem solved...
Let me know if this worked for you ... -
My burner is compatible w/nero, there is no firmware update as of yet, and all my connections are fine. The same prob, as soon as i try to burn anything using nero (audio, data, vcd...) i get "invalid Field in Parameter". AAAAAAAAAAAARRRRRRRRRRRGGGGGGGGGGGHHHHHHHHHHH!!!!! HELP!!!!
there is supposed to be bootmenus to fix this problem and let you choose between the two...they are available for download at the Nero site, but THE LINKS DO NOT WORK! If anyone knows where to get these could you please enlighten us...also if it doesn't work on ME, I'm screwed, cuz i need both adaptec and nero........
OK!!!!! I got it fixed!!!! After waiting for a few days for a response from nero i got this response : "I am sending the file "mmc.dll" as an attachment. When you receive it,
place the file in the "C:\program files\ahead\nero" folder. Restart your pc
and duplicate your problem. Let me know what happens. "
Well i did it and Nero now works flawlessly.
His name was Alfred Valerio and his email is avalerio@nero.com. SO for those who have been experiencing this problem, email him and ask for that file. GOOD LUCK!!! -
This works!! Download what Manny posted because it works. I just burned my VCD FINALLY
lata
Mike
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 03:12 -
Parameter Incorrect?
By The Monkees in forum ComputerReplies: 3Last Post: 18th Mar 2010, 17:41 -
Nero Vision 5 with ADVC-100 - wrong field order in NV5
By vcddude in forum Capturing and VCRReplies: 10Last Post: 28th Nov 2008, 17:22 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 22:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 5th Dec 2007, 23:19
