I have an Emac 800 with an superdrive.
Apple system profiler gives the specs
Device Revision - D031
Product ID - DVD-RW GCA-4020B
Vendor ID - HL-DT-ST
My question is "Can this drive burn DVD-RW's" I have heard Apple has disabled some of the RW functions from the drives.
The easiest way is to just try it
If its an RW drive it will burn to RW's
just pop a rw disk in and try the burn - then you will know if it does or does not
There are lots of posts in th Apple help forums (apple.com) that deal with this question. Briefly, yes the Superdrives do support DVDRW. If, however, you are using iDVD with DVDRW discs, there is a trick that is needed to get the disk recognized. As I recall, you insert a DVDR disc when requested (prior to the burn). Then as encoding poceeds you eject the DVDR and replace it wih your DVDRW.
I do not know which manufacturer made the SuperDrive in the eMac, but I suspect that they would use the same OEM as in the iMac, since space considerations are the same (as opposed to the Powermacs which require a much thinner drive).Originally Posted by tcrider
Toast 5.2 supports burning DVD-RWs in my iMac G4. My Powerbook G4 "12" will not burn DVD-RWs (yet).
Available Blu-ray drive with SONY VAIO & Apple Mcbook laptops
By vikas.babu in forum MacReplies: 0Last Post: 22nd Mar 2011, 05:52 -
Can I Drive an Apple LCD directly from a DVD player?
By xmiinc in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2009, 21:49 -
HDV to Apple PNG or Apple Motion JPEG A
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 1st Dec 2008, 16:46 -
question about SUPER
By Shaorin in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2008, 05:08 -
Question about SUPER
By AlecWest in forum Video ConversionReplies: 0Last Post: 17th Apr 2008, 20:24
