Hey guys,
I have some PAL DVDs which cause my TV to roll the picture. So rather than re-encode everything, I changed the bit-flag in the ifo to NTSC and played it back and it seemed to work just as well. Of course this is now an xDVD.
But I tried the same thing on my Pioneer 343, and it seems to get a corrupt picture due to the res not being NTSC as expected. Anyways I was wondering if the Pioneer 343, or most DVD players for that mater can display video at 25fps even though the flag is set to NTSC? Simply, the reason why I want to do this is because I don't want to shift the audio to match the speed of a 29fps converted video from pal. In addition, I can't get a perfect IVTC on my source DVD as it always leaves leftover interlaced lines. Also for some reason it makes the movie 60 frames a second? Wouldn't you just be making 1 frame from 2 fields?
Anyways, I think if everything is NTSC except the frame rate, theirs a good chance it would work, but I just wanted to ask around.
Results 1 to 1 of 1
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
Film -> PAL (change fps and a bit of restoring)
By elmuz in forum Video ConversionReplies: 36Last Post: 31st Aug 2010, 17:53 -
How to change NTSC to PAL in adobe premiere elements 7
By jarko in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2009, 20:28 -
Change from PAL to NTSC DVD LG DR-4800
By mairel in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Jul 2009, 13:40
