I'm converting a relatively small file; the program estimates it will take 10 hours. It is also running very jittery... I put it on high quality, but ten hours seems way too much for a music video.
Any help?
It depends on your CPU (and to some extent ram) the encoder you use and the settings within.
For ex, I had a K62-500, to convert a 90min DivX file to MPEG1 w/ TMPGenc took 18hrs. Now I have a Tbird 1.2Ghz, CCE will convert a file to MPEG2 at 1~1.35x the source run time!
So w/o knowing more about your system, and the settings you're using in TMPGenc it's hard to say. -
I was using the settings described by VCD helper.
I have a K63 400, 128 megs of RAM. It is about a 6 Meg file... I waited out the twelve hours, and the finished file didn't even have sound... could it be that the source movie is so compressed that it is just a bastard to convert?
Thanks for any help...
Winavi Runs Slow On Old Computer Any Way To Speed It Up
By DJboutit in forum Video ConversionReplies: 6Last Post: 3rd Jan 2010, 18:36 -
convertxtodvd suddenly runs very slow
By aruwin in forum Video ConversionReplies: 13Last Post: 25th Jul 2009, 02:39 -
Laptop runs REALLY SLOW!
By Squid_uk in forum ComputerReplies: 22Last Post: 6th Oct 2008, 23:34 -
v2.5.3600 runs very slow and driving me nuts...!!!!
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 6th Oct 2008, 10:00 -
video runs slow
By Madgelina in forum EditingReplies: 0Last Post: 8th Feb 2008, 18:45
