Hi there,
Ive managed to convert a good few avis now using the guides on this site. Ive recently started to have a few problems however. When using virtual dub it has started to tell me that no proper dcompressor coul dbe found. Ok i think , i will try avi to wav....this works fine BUT when the video is finally encoded and burnt on a disc the sound is very choppy, it sounds as if well.......choppy...you know what i mean
The other thing is that TMPEG has started giving me problems, Ive been starting to get an error " read error occured at address 004c7ff3 of module tmpegnc.exe with 03387af8" this happens quite a lot. I increased the DirectShow Multimedia File Reader prority but when i did this the video was kind of garbled when the motion was fast. the funny thing it had been working fine and i had managed to encode half of the movie with no problems and was about to start on the next half that these problems started. weird eh?
Any ideas?
1. Sounds like you have ac3 audio, check out my post here
https://www.videohelp.com/forum/viewtopic.php?p=525099&highlight=#525099
2. I used to get that error also, not sure of a definitive solution, i just uninstalled and then re-installed and it works great now.
3. Don't name your posts like that, make it an insight into your problem so more people read it.
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 13:36 -
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 22:47 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 23:25 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 11:57 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 18:41
