Here is the problem, I went into MY COMPUTER and noticed that my 60GB hard drive was showing details of having a 47GB capacity. So I went into my DISK MANAGER and seen that I had 13GB of unallocated space in my LOCAL DRIVE C. I dont know why this happened, I have been having this computer for about 1 1/2 years and nothing like this has ever happened. When I went to format the remaining 13GB it would only let me assign a new letter. My question is how can I rejoin it with the other 47GB to have the original 60GB.
THANKS IN ADVANCE,
SLICK RICK![]()
Is that the only way, if so how does it work.
SLICK RICK
Originally Posted by lordsmurf -
Go to Power Quest's web site and look up Partition Magic. They may have a users manual that you can download. You can buy the program at most computer stores, such as CompUSA, for under $50.00 US dollars. The program really does work and is well known to all advanced computer users. Before using the program, it might be a good idea to find out what caused this, because if it did it once to your system, it may do it again. Finding the cause is the hard part and could be caused by several things. Anyway, good luck!!!!!!!
@txparoah & burnmaster2003,
Thanks for the help.
SLICK RICK
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 16:58
