can anybody explain to me why a 25fps movie soundtrack at 44100Hz
must be time stretched to fit in the same movie at 24fps ?
there is a similar stuff in BeSweet named "NTSC to PAL audio convertion".
in my mind, the movie duration is independent of video framerate.
and video framerate is independent of audio framerate. So what are
theses stuff ?
in my case, I record french version of totoro from Videotape: 25fps
I have also the japanese version from DVD: 24fps
The most common way to convert between 24fps and 25fps is just to run the video at the speed you want. By just changing the playback speed you avoid having to add or drop frames (which means you avoid jerkiness), but you change the playing time of the movie slightly. If you change the length (time) you have to adjust the audio to match or it will start out in sync and gradually get farther and farther off throughout the movie.
If you were to convert a 25fps movie to 24fps by just dropping 1 frame every second you wouldn't need to change the audio length, but a lot of scenes wouldn't play smoothly. -
Because the video is showing the same number of frames, but at a different speed, so the playing time is fractionally different.
If its a downloaded or otherwise AVI copy of the japanese one (i assume you're doing something im thinking of doing - applying the non-disney version dub to a nice new dvdrip.. except here its english not french
) then you may get away with just changing the speed of that to 25fps without having to reencode it at all.
If however you wish to keep the jap video intact or there are other reasons... load french audio into e.g. Cooledit. Change playback speed to 23976hz (or 24000hz if it's actually 24.000fps). Re-Sample to 25000hz. Put speed back to 44100hz (and save). The sound will now play slightly slower (and ever so slightly lower pitched) and in time with the slower frame rate.-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
in fact I found some information about this pb.
PAL movie are produced from 24fps movie simply
accelerating playing. So audio is quicker than original.
My pb is more complex because my french audio source
(videotape) is not regular. so a simple timestretching
do not work.
thanks for you help.
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 17:32 -
Framerate Conversion
By rackball in forum Video ConversionReplies: 10Last Post: 11th Aug 2008, 04:04 -
Changing the framerate during conversion
By 2nickelstripper in forum Video ConversionReplies: 2Last Post: 7th Dec 2007, 07:46 -
Framerate conversion question - 30fps source
By Killer3737 in forum Video ConversionReplies: 17Last Post: 8th Aug 2007, 13:30 -
Audio framerate conversion?
By pYShTr in forum AudioReplies: 2Last Post: 28th Jun 2007, 11:05
