can i use MainConcept like TMPGenc to make vcd's what i wont to do is put 1 movie on 1 disk i change the bitrate in vid & sound on TMPGenc to do it but MianConcept dont wont me to on vcd settings but MainConcept is FAST and it looks good on standerd vcd's so i was just a wondering
my version of MainConcept Mpeg Encoder is 1.03
Results 1 to 9 of 9
Yes, you can, but I recommand you get v1.3.1 instead of 1.0.3
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
thanks for the info can you point me to a guide on how to do that stuff TIA
wish i knew when i started vcd stuff what i will know in a few years learning all the time i hope LOL -
You can use my own guide here on DVDRhelp (or any other of the webpages) it is supported on (labDV/Digest/mpegnews...) if you need any help with the guide, just let me know 8)
Best Regards,
Sefy Levy,
thanks Sefy for the help i call myself looking for a guide and have not found one but i looked a little harder and found your guide gonna try it out tonight a link to it for anyone https://www.videohelp.com/sefy/?id=encoding10.html
Let me know if you need any further help! and i'll do my best
Best Regards,
Sefy Levy,
Is the MainConcept enocder that comes with Premiere as good as the standalone version?
rgr that Safy thanks Rich
Should be Michelle! I didn't even know there was a Premiere version for it.
Best Regards,
Sefy Levy,
Rovi buys MainConcept
By lordsmurf in forum Latest Video NewsReplies: 5Last Post: 17th Feb 2014, 01:14 -
AVI to MPG with Mainconcept
By electrontau in forum Video ConversionReplies: 5Last Post: 1st Aug 2008, 14:34 -
Mainconcept DV Codec in VirtualDubMod
By WinSpirit in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2007, 23:31 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 20:14 -
Mainconcept DV Codec Vs. The Rest
By SeeNoEVO in forum Video ConversionReplies: 25Last Post: 5th Jun 2007, 08:16
