I use pinnacle 8.5 but it takes hours to render the file.
I tried using ulead dvd workshop but it cannot create moving image menu's and limited to the way your main menu pages are created.
neodvdplus renders the video very quickly,but is limited in creation of menu's
Is there a dvd authoring program out there that renders in real time and has an option to create moving images in the menu and you have wide options in creating you menu page?
Please Help
Corey
What about using PS8 for editing, another soft. for encoding and back to PS8 for DVD Authoring ?
Try to look here....
Pinnacle Studio 8 and DV home video editingPinnacle Studio 8 and DV home video editing (ver.9 already home) -
Try Roxio Video Wave Power Edition 5. Encodes much faster than Pinnacle, and it's a solid product (not like Pinnacle)... It doesn't have as much features, but they all work.
have you tried DVD Lab?
do a forum search, you can find the latest beta and check it out for 30 days.
- housepig -
DVDLab is by far the best authoring program out there for less than $600 (it will only cost $79, although the beta is now available for free). I suspect Adobe's Encore will give it some competition regarding higher end features, but it's quite possible DVDLab can evolve to even beat it.
If you haven't tried it yet you need to -- it won't cost you anything and I'm betting you'll get hooked."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Ulead DVD WORKSHOP does allow for creation of motion menus:
http://www.ulead.com/learning/dws.htm
Jerry Jones
http://www.jonesgroup.net
DVD authoring program for mac
By BIFFtheSTIFF in forum MacReplies: 2Last Post: 25th Apr 2011, 03:23 -
Which dvd authoring program could I use...
By sagat93 in forum Authoring (DVD)Replies: 5Last Post: 14th Oct 2009, 22:43 -
which dvd-authoring program is better?
By siluet in forum Authoring (DVD)Replies: 9Last Post: 8th Oct 2008, 15:25 -
What's a good dvd authoring program to use?
By zanos in forum Authoring (DVD)Replies: 14Last Post: 3rd Mar 2008, 12:11 -
The Best DVD Authoring program
By Random490 in forum Authoring (DVD)Replies: 6Last Post: 12th Dec 2007, 05:10
