I tried to make a VCD from a 780Mb video file on VCD using VCDeasy and it only burned 700Mb of the file. When I used Nero I was able to get the whole 780Mb on the VCD. Is there a VCDeasy setting that Im missing to be able to burn >700Mb? I have the latest version of VCDeasy v1.1.5. The VCDeasy website says that I can set the over burn from the Tools-Cdrdao screen but I didn't see it there.
The overburn setting should be available to select when configuring VCD easy to recognize your drive. The help files should help you find it if your not finding it. And it may be burning only 700 mb files because your using the wizard mode that burns a standard VCD. You have to use the manual mode to burn a non-compliant disc.
VOB File and CD overburn Query
By scott274 in forum Newbie / General discussionsReplies: 8Last Post: 17th Nov 2009, 02:54 -
What Are The Best Setting For Youtube
By SailorStar1 in forum Video Streaming DownloadingReplies: 2Last Post: 10th Jul 2009, 04:27 -
DVDPlayer B.L.E. setting?
By wiseant in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Jan 2009, 13:52 -
which setting should i use
By fruitpassion in forum Video ConversionReplies: 4Last Post: 23rd Aug 2007, 20:58 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 10:08
