I know this has been asked a lot of times, but most of my searching the results was cards with tuners. I will be inputting from my satellite receiver via s-video, so do need a tuner. I currently have the Xcapture card and have been unable to make it work right.
So which capture card without a tuner do ya'll recommend? I do not mind paying a little more if the card works easier and has better PQ and audio. I also think it should have its own software with it for making captures.
Results 1 to 11 of 11
reubenray just wondering what problem are having with your Satellite Receiver and S/Video?.
Me my PVR 250 get a long just fine with my DiskNetwork Satellite Receiver via S/Video. -
I think it is mainly the Xcapture card that is causing the problems. Either that or the software. I have tried several of the most popular software and I have yet to get a capture that I would keep. It either has bad PQ or either bad sound or no sound. I have and am still trying AMCAP, VitualVCR, Flyds, SVCDcorder and iuvcr. The live picture and audio is pretty good, but the recordings suck.
Another thing that bugs me about the Xcapture is having to reset the input everytime I turn the computer on. -
Adaptec VideOh PCI for hardware MPEG2 capture at a reasonable cost.
{yes, I know the bundled software stinks} -
Try the Canopus ADVC-100. Its the top user rated capture device on this site. Its also a non-tuner.Originally Posted by reubenray
One question about the Canopus cards. I do not have anything that has firewire. I will be inputing from my satellite receiver via s-video.
Will this card still work with my setup? -
The ADVC-50 is similar to the ADVC-100 but is internal (and I don't think it has the analog video-out capability.) Its a PCI card and not firewire so it should work with your setup.Originally Posted by reubenray
http://www.canopus.com/US/products/advc-50/pt_advc-50.asp
Using S-Video To Capture Into Hauppauge 1600 TV Tuner Card
By waldodiodio in forum Capturing and VCRReplies: 4Last Post: 1st Nov 2010, 18:49 -
Help Choosing Capture/Tuner Card...or Other wise
By drtalk in forum Capturing and VCRReplies: 2Last Post: 3rd Sep 2010, 18:46 -
recording cable HD channels on pc tuner/capture card
By Zipbiscuit in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2009, 10:52 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
Good suggestion.
