im trying to create an svcd from a dvd that has multiple streams on it..
eg episodes
there are four in total on the dvd but they are all seperate.
I want to create one cd for each couple of episodes...eg cd 1 will have episodes 1 and 2..cd 2 will have 3 and 4..
How do I go about joining the Vob files...or creating a menu and putting both episodes on the one cd?
each episode is 40mins ...
is it even possible to put 2 episodes on one cd? (while maintaingin quality?)
Rock On
Ive ripped episodes and it would depend on the end filesize.
If you used VBR 2pass and used a calculator to figure out wut would make 2 fit on 1 cd, it may be possible. but i think thats for more like 20 min episodes. 40 mins i doubt you could fit 2(cut quality mostlikely but how much i dont know, may be OK).
Do you have each episode ripped as a vob file individual from the dvd?
or all 1 vob. or have you got this part done?
There are VOB tool programs that can separate vob sections but im not sure about joining...check them out. SVCDs u could put a menu up 1 enter for this episode, and 2 enter for the other episode. Its not interactive like a dvd but you can add thumbnails. -
First I don't think you'll get a quality svcd with 80 minutes of full screen video per disc. Personally I wouldn't try to put more than one episode per disc.Originally Posted by vamp1re
For multiple episodes on one svcd with menus you could go ahead and render each episode to a separate file then throw everything including your menu stills into TSCV. There are guides on how this is done so I'm not going to explain it here.korth
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 14:38 -
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2011, 23:34 -
Chapters from TV Series
By 80r in forum DVD RippingReplies: 1Last Post: 8th Jun 2010, 17:05 -
Help Ripping TV Series
By fordprefect138 in forum DVD RippingReplies: 9Last Post: 21st Dec 2009, 09:31 -
TV Series Subs ???
By LusKereN in forum Off topicReplies: 3Last Post: 17th Oct 2007, 10:22
