Is it possible to convert *.rm to a MPEG file? I have a lot of RM video, and I would like to make some VCD's out of them. Thanks for any help!
~fayzex
You can, but its a pain in the butt. You first need to convert the RM to AVI and I've only come across one application that does a half way decent job, meaning it won't work will all RM files, just some. Just a DOS hack, but someone came up with a GUI front end. Get both.
Its called TINRA and the front end is called TINRA GUI
Why the weird name? It stands for This Is Not Real Anymore
http://tinragui.tripod.com -
go to http://www.techsmith.com they have a program called camtasia its a video caputre tool works really well for any video file. I used it for a rm and burned to vcd just fine good luck
