Hi guyz.I am a newbie , the problem i have is that a friend gave me 'DARKNESS FALLS'' on dvdr .It was given to me on a yellow discwrite.He has given me other bits and pieces before and all work fine.Last night i went to watch DARKNESS FALLS on my pioneer stand alone dvd player.I got to the main menu and pushed '' play movie '' i was then presented with a choice of wide screen and full view.I have tried both and cant seem to get passed this part. Can anyone help me on how to sort this movie pout.I have a dvd writer so can sort it out.Thanks in advance.
i don't think its legal to hand out a back up without the original. and don't cross post, newbie.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
I would call bad RIP ! I made this disk last week, and it's kinda tricky to makeOriginally Posted by txpharoah
no, this DVD have Fullscreen and WideScreen format on it.. IF you remove one the "bad" way (ie: removing only vobs) it could crash.. I had this problem with my first burn... second burn I made movie only.. too much problemOriginally Posted by txpharoah
Enter the movie via scene selection and then chapter 1 then choose version kept,this should stop looping problem. KNOWN duel version problem. I'm working on EASY fix, not so easy to fix so far. IC7 always does this it seems on duel version where one is removed [RE; 16:9 and 4:3] on same disc.
Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
some will play and some wont.
By kushy66 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2011, 21:32 -
Help - Y wont my burned movie play
By sweetcheeks82 in forum DVD RippingReplies: 4Last Post: 18th Aug 2011, 13:37 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
xp wont play movie
By natty in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2010, 12:26 -
8x DL wont play in PS3
By Onceler2 in forum MediaReplies: 3Last Post: 6th Aug 2009, 14:16
