2 questions:
1: I just bought a TDK indi dvd+r 4x burner, and used it to burn mpegs onto a dvd+r as data(mpeg, not vcd) using EZCD & DVD 6.. My problem is that I gave it to my friend to watch the clips from his dvd drive in his comp, but his comp can't even see that he has a disk inserted in his drive. I thought that all dvd drives could read dvd+r disks (I don't know what dvd drive he has, but his comp is only about 1 year old). Is there something I could be doing wrong, or is there a list like the 1 here for stand alone players saying what drives can read dvd+ or -r disks?
2: The other thing I noticed is that it says everywhere that a dvd+r can hold 4.7gigs, but it can hold that much. Does anyone know how I can figure out how much data 1 disk will actually hold?
Thanx
Results 1 to 10 of 10
Not all DVD player's will read DVD+R or DVD-R. Some DVD player's will only play really DVD's. If you can return your DVD burner You might want to get a DVD-R. When HD-DVD player's come out they will not read DVD+R but they will read DVD-R
I don't mean to be picky, but it is 4,700,000,000 bytes, not 4.7 Gigabits.Originally Posted by txpharoah
4.7 Gigabits would be 4.7/8 Gigabytes.
But yes, 4.7 Gig when described by a drive manufacturer treats as 4.7 X 1,000 x 1,000 x 1,000 bytes = Good marketing. Technically, however 4.7 Gb is 4.7 x 1024 x 1024 x 1024 bytes.
So 4,700,000,000 / (1024x1024x1024) ~ 4.38 Gb
PS
Some say 4.48-ish if they treat 1 Gb = 1024x1024x1000.
Eg. Nero.The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be. -
Thanx for the info.
I can't believe that they actually say a dvdr will hold 4.7 gigs(they should be shot) I mean, when they say a cdr can hold 700 megs, you can actually fit 703megs on it, and thats with out having to overburn.
1 last question I just thought of, does anyone know if there is a proggy, that someone can d/l so it makes it possible for them to view a dvd I make them if their dvd rom drive doesn't see the disk now? Kind of like a general driver update or firmware updatethat should work on all drives? (probably not, but I can hope
thanx again
No such beast. (Or at least I have never heard of it if there is).does anyone know if there is a proggy, that someone can d/l so it makes it possible for them to view a dvd I make them if their dvd rom drive doesn't see the disk now? Kind of like a general driver update or firmware updatethat should work on all drives?
Would have to be drive specific.The glass is neither half-full, nor half-empty.
ChillBill you can use POWER DVD to view a DVD on the hard drive and you can use www.dvd2one.com if the DVD will not fit on the blank DVD or DVDshrink thats free software
[quote="nerdboy69"]
quote]
What happenend then ?
Actually, the max for a DVD-R is 4,706,7XX bytes. There is currently no overburning standard for DVD recordables.
letterbox problem on burned dvd ...
By perik in forum MacReplies: 5Last Post: 8th Jun 2010, 03:01 -
Problem With Stand alone DVD player and Burned Dvds
By tealmarlin in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2009, 15:02 -
Menu problem DVD-- burned in MythDora4 (dvdauthor)
By media601 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 23:12 -
Problem Playing DVD I burned
By hollywoodfussell in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2007, 08:46 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37
