I've been trying to copy a VCD (for my own personal use, of course) using Nero. I've tried every possible means: burning CD to CD (picture came out really bad, pictures were jerky, sound was squeaky. Burnt it at 4X), transfering the data from VCD to hard disk, then burning it as a data CD (I popped it into the player, the VCD ran, counter was moving, just no image or sound, just a blue screen and silence).
The VCD comes in a set of 3 CDs, I'd copied the other 2 CD to CD at 12X without any problems. I've had problems with just this one CD.
Would be greatly appreciative if someone could provide me with some assistance! Cheers!
<font size=-1>[ This Message was edited by: src12 on 2001-09-18 23:09:33 ]</font>
You might try slowing the read speed down on Nero and write speed down. I've backup playstation games that my kids have. I usually don't use Nero for that purpose I used CloneCd on the playstation games. I read and write at 1x. I've tried higher speeds and I usually get problems. I don't understand why speed makes a difference with playstation but it does. Maybe this might make a difference in your case.
It looks like you have a problematic disc. You can try copying the DAT file inside the MPEGAV directory to your hard disk. Then run VCD Gear to convert the DAT file to MPG. Finally, use Nero to create the VCD. Ensure that you are creating a VCD and not a DATA CD since a VCD has additional directories for control information while a DATA CD does not have this.
I tried copying the .dat file and then creating VCD from it, but the effect was the same- jerky images, squeaky sound. I've also tried burning it at 1X! Still didn't work. I'm now thinking if I should try it with another VCD of the same title. Sigh!
IMGburn 2.5.1 copying problems
By NickiMitch in forum DVD RippingReplies: 1Last Post: 7th Jun 2010, 08:58 -
Problems copying CDs on Mac
By Nilfennasion in forum MacReplies: 3Last Post: 3rd Jul 2009, 08:15 -
Problems copying off my cable box now that I have HDTV
By TheRybot in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Jan 2008, 16:29 -
Problems Copying 2 Movies on 1 DVD with a menu!
By UmmAddan in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2007, 11:42 -
Anyone had problems copying Dvd's with HP drives?
By Blumphf in forum DVD & Blu-ray WritersReplies: 53Last Post: 31st May 2007, 20:40
