I used Smartripper to rip a movie to the hard drive, then used DVDX to covert it to AVI using a 2400 kpbs bit rate with the Divx codec. If I rip only a segment or two the movie will play back just fine. If I rip the entire movie, then NONE of my players (Mediaplayer, Divx, QT, Etc.) will play it. If I use the Divx player I get the following error message:
This file cannot be opened
StreamSourceFilter::eekFromBeginning(0) out of readLimit range: -1
Anyone know what could be causing this? Movie is Apllo13, and I can't for the life of me figure this one out.![]()
Thanks!
Foochey
PS-I'm using WinXP Pro with NTFS partition to copy the movie. Final file size after decoding is 2.1Gb using a 2400 bit rate in Divx.
"Before you give somebody a piece of your mind, make sure you can get by on what's left"
-S -
I've had problems for some reason with big divx files, try splitting it into 3 pieces.
"Mustard?! Don't lets be silly now. But lemon, thats different, thats nice." - The Mad Hatter
Avi file won't play
By billyman115 in forum Software PlayingReplies: 3Last Post: 20th Jan 2012, 16:04 -
avi won't play
By fabre in forum Software PlayingReplies: 2Last Post: 25th Aug 2011, 00:26 -
recovered avi's won't play
By veger045 in forum Software PlayingReplies: 5Last Post: 9th Jan 2010, 21:00 -
AVI to DVD but won't play
By sumire in forum MacReplies: 11Last Post: 8th Feb 2008, 13:01 -
avi won't play on quicktime
By crazymf2788 in forum MacReplies: 2Last Post: 30th Aug 2007, 09:36
