Captured a 2hour 2 minute DV clip (from video player via camcorder & i-link). 28gb in total, plays fine on PC.
Tried to convert it to MPEG2 using TMPGENC 2.58. Used instructions as per guide, change the CBR to 3500 so that it would fit on disk and waited 8 hours.
When I came to look at the MPEG2 version, the audio is perfect but the video only shows 1 frame out of each 25, so it jumps like and is unwatchable.
Played with the settings a few times and waited 8 hours per re-try. Same each time.
Gave up after 5 attempts and used Ulead DVD MovieFactory 2, this worked perfect 1st time.
I however prefer TMPGENC as a tool, so I would be grateful if anyone could offer any help.
Thanx
Simon
First things first. Use the Source Range option to preview your work. Select only a small part of your source (like a 2 minute clip), and preview the output to ensure your settings are correct. Using TMPgenc, this is almost a requirement, or your asking for frustration.
That said, without knowing what settings you used in TMPGenc, we all be guessing as to what you did wrong. What format are you converting to? Also, did you utilize the built in Templates using the Wizard?Impossible to see the future is. The Dark Side clouds everything...
MPEG2 to MPEG4 conversion
By altavistasf in forum EditingReplies: 2Last Post: 11th Jun 2010, 23:35 -
mpeg2 to mpeg2 conversion
By asdfen in forum Video ConversionReplies: 9Last Post: 4th Oct 2009, 13:45 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 00:31 -
TMPGEnc problems with RMVB -> Mpeg2 conversion
By rebel316 in forum Video ConversionReplies: 2Last Post: 7th Aug 2007, 04:33 -
Blocky conversion DV-->Mpeg2 @ 9000Kbps using TMPGEnc 4.0
By kamaleon in forum Video ConversionReplies: 34Last Post: 15th Jul 2007, 17:25
