hi not sure if this is the right forum to answer my post,
i downloaded a thx sound test clip from the thx website and its in windows media video file, what id like to do is to put that test at the begining of my backup DVD's, would i have to convert this file and if so with what tools?
Also would i have to rename DVD structure so that it would played synchronised one after the other.
regards
kas187
Can anyone help here ? i'm not good with DVD Burning as I don't own a DVD Recorder myself 8)
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
you can convert it with ulead and vegas products to mpeg2 /ac3 - probobly others as well , but if it has that media management lic stuff in it -- i don't have a clue...
as for your second question -- i don't understand it ..
you need some sun also -
what i mean is that say if for example i decrypted a film say shawshank redemption on to the harddrive and wanted to insert an extra VOB i.e. Dolby Surround Sound clip before the menu, how would i do that, presumable i would have to rename some of the vobs and create new ifos and bups?
kas187
what do you mean i need some sun, im dying with hayfever here
Demux a Dolby Surround 2.0 file into separate streams?
By Xoanon in forum AudioReplies: 27Last Post: 2nd Jul 2021, 09:21 -
Need to make test tool to test Dolby
By djai in forum AudioReplies: 0Last Post: 9th Jun 2010, 07:01 -
ac-3 pro plugin and dolby surround
By ecc in forum AudioReplies: 1Last Post: 24th Dec 2009, 12:14 -
Converting WAV file to Dolby Digital® 5.1 Surround
By roma_turok in forum User guidesReplies: 18Last Post: 16th Nov 2008, 23:32 -
Dolby Digital Surround EX encoder
By grasswhopper in forum AudioReplies: 1Last Post: 18th Aug 2007, 00:49
