Hello,
My system is a P4 1.7mhz with a dedicated 80 gigs 7200 8mb cache WDC to capture.
I'm using Win XP with virtualVCR. I'm dropping consecutive frames after about 55 mins of capture. It's not some frames here and there, it's like a bunch of frames at the same time.
Now I'm capturing the vcr blue screen, so no tapes in the vcr and I'm still dropping frames after about 55 mins.
I deactivated all services in XP, all background tasks, no difference.
I really don't know what's happening, any idea??
Pitou.
When I set my resolution too high, the same happens to me. What settings are you trying to capture at?
Hello. -
Hello,
I capture at 720x480 30 fps with a BT848 chip. I'm using Huffyuv as the codec but I also tried MJPEG with a very low quality so minimize the transfer rate, no luck.
Please take note that it was working before. I had to reformat for some reason.
Also, this happens about every hour. So I loose frames at 100000 frames, at 200000 frames, etc.....
I sat down in front on my PC and everytime it looses frames at bout every hour, I can see the HD LED become solid RED for about a second. So that's why I suspect the HD of the OS.
I'm going to try Win2000 instead of XP
Thanks for taking time to help me.
Pitou. -
I tried turning cache write off, in the device manager of XP.
But then I get a lot of frames drop all over the place.
btw, I use Virtual VCR since I want a WDM capture software
Pitou. -
Hi,
I've juts installed win2000 and it works great!
Not a single drop in more than 2 hours
Yessssssss!
Pitou.
turn off/disable VCR On Screen Display for capturing
By lesleyjudy in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2021, 08:01 -
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
DVD frame dropping.
By videosam in forum Video ConversionReplies: 20Last Post: 4th Aug 2010, 05:00 -
JVC VCR - how to defeat the blue screen?
By theaveng in forum Newbie / General discussionsReplies: 1Last Post: 20th Aug 2008, 07:22 -
Capturing the blue screen with white DV tape graphic
By fusiblelinks in forum Newbie / General discussionsReplies: 5Last Post: 27th Jun 2007, 22:33
