When i convert an avi file with TMPGEnc and i split it in two parts the first part is allways perfect and after doing the second part it is allways jerkey. I must be doing something wrong to get that result.
I do the first part by choosing start frame then end frame, after first part is done i choose the second one by starting where i finished the first part and do the same thing. Second part is allways jerkey. How come first part is 100% good and second part is Jerkey??What i'm i doing wrong.
It happens every time i split a movie.![]()
Results 1 to 10 of 10
I dont use AUDIO GAP CORRECT when i do the second part, does it have anything to do with my jerkyness and if so how do i figure out this gap??
I am using the one in Settings that says SOURCE RANGE. Double click on it then i do the split. My problem is that i never done a second part that is not jerkey. Dont understand why, because i do not change any settings so why is the first part perfect and the second part jerkey?? I also checked for bad frames with Virtualdub and there is none.
Alright, then try getting Virtual Dub and cut your AVI source into 2 AVI files, before encoding the seperate MPEG files. The encode each AVI separatly.
Thanks Neo for beeing kind. I will look to it and follow your advise. Do you think that will solve my problem ???
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
No Audio in Part of Video
By wingspar in forum EditingReplies: 2Last Post: 31st May 2011, 16:43 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
How old are you - part 2 (no lying now)
By yoda313 in forum PollsReplies: 95Last Post: 4th Oct 2009, 10:00 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36
