When using TMPGEnc to encode both The Phone Booth and The Hot Chick the picture is perfect but after 10 to 15 mins on The Hot Chick and 50 mins on The Phone Booth the sound starts to become garbled it sound as if its just the bass sound, any ideas as to why this is happeing?
Thanks In Advance
Will
What is your source ? AVI or DVD ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
As you have downloaded these files I would say that they contain bad frames, you could try removing these. If this does not work I would recommened downloading the file again.
If they file is a downloaded AVI (DivX/XviD) then it is possible to use VirtualDub to frameserve it into TMPGEnc as well
Best Regards,
Sefy Levy,
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 21:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
