help needed putting vcd onto a PAL dvd!!
i have been trying for about 4 weeks and i still cannot get it right.
im trying to put 4 tv eps onto Pal dvd.
i originaly tried to but them as a mpeg 1 file
with movie factory 2 and the guide on this web site
the stats of the meg were as follows
frame size 352 x 288
brite 1141
audio 44k 244 stero layer 2
this did not work, so i tried to convert them to svcd
with tmpeg, and again the how to convert vcd to svcd guide
on this web site
and burn them to dvd again using the movie factory 2 guide.
but agian no joy.
when using the moviefactory guide
the only thinfg that does not match up like in the guide is
required/availbe hard drive
required/availbe disc space
these are way out and not the same like in the guide.
maybe im using the wrong settings in tmpge,
i just dont know, i really need some advice and help
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
What happens when you try to encode them with TMPGEnc using the DVD settings?
Hello. -
i have not tried the dvd settings
just vcd & svcd could this be the problem?
and if so what settings should i look out for? -
Only worry about changing the DVD settings if the resultant files do not work out.
Hello. -
Tip (from personal experience), create seperate mpeg's, not one big one, if you plan to use Ulead Movie Factory.
I kept getting crashes trying to set menu points in one big mpeg, but not with indiv. ones.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
putting all VCD into a HD media player
By jjhung88 in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 11:09 -
Help putting together a DVD
By Keano16 in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2008, 12:56 -
putting a link to website on vcd menu. Is it possible.
By Mark-It in forum VCDEasy GeneralReplies: 1Last Post: 21st Dec 2007, 23:08 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30 -
Putting two DVD's into one
By Victor Hen in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 11:09
