Results 1 to 9 of 9
  1. Can't seem to get the audio to syc properly when I burn an svcd with nero, I've tried playing with the syc settings on tmpg when I convert to mpeg2 from divx but no matter what I try the audio always seems to lag behind slightly. I'm playing the discs back on a Toshiba SD210 dvd player. Hope someone can help Nick.
  2. is the audio always the same amout behind? or does it slowly sorta go out of sync?
    look at the tutorials on this forum (under "howto" -> "edit")
  3. Are you converting in nero ?
    Does the file play okay before you burn ?
    How are you converting ?
    What speed are you burning at ? (have you tried changing this)
    Have you tried changing your media ?
    If it's wet, drink it
    My DVD Collection
  4. The sound starts out behind the video from the beginning. I convert using tmpgenc. The avi and converted mpeg are all fine. The audio and video get out of sync only after i use ifoedit to create vob files.
  5. LOL. sorry, wrong topic.
  6. i had audio sync problems when i used vdub then tmpenc then i just used the audio from the original divx or xvid i dont understand why someone would even use vdub to make wav.
  7. patterson, its becouse some peeps have audio sync probs
  8. Going back to the original question ...
    I too have a Toshiba SD210 DVD player.
    It just does not handle SVCD's correctly. Audio sync problems are widely reported for this unit as you will see under the DVD Players link.
    I gave up and bought a DVD burner - NEC 1100 - excellent machine!
    Chris
