Hi
This is my second attemp at using DVD2DVDR. First was with Gladiator PAL and had no probs at all. Yesterday I tried Road to Perdition and go the error "Vinf_open() failed: Bad data<c:\New Folder\Road_to_Perdition\video_0xE0_New.VAF>"
This happens just after it has ripped, checked audio and run through DVD2AVI.
Now trying spiderman to see if it does the same thing.
I'm using latest DVD2DVDR and CCE 2.5
Any idears would be gratefull.
Daz
It sounds like CCE is having trouble reading the file it created on the first pass. You might want to delete it then scandisk/defrag and start again.
would it be that though as the error comes up before CCE actualy starts running. The soiderman I'm running is nearly up to that point so Ill post my result to see if its just that movie.
Daz -
Spiderman was no probs at all. Went straight into CCE and started encoding.
Anybody know why one particular movie might do this and maybe a way round it.
Cheers
Daz -
I've seen a few movies that would had something in the video that would freak CCE out quite badly over and over. I'd suggest manually ripping the video and encoding it with the robshot method (guide in the guides section at doom9.org. See if it gives the error that way.
If its a .vaf error the it almost has to be CCE related.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 14:39 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
