Is this possible?
I've got a Sony Vaio PCG-FX240 that I feverishly edit video on-- about 3 years now. (Adobe Premier). I purchased an external firewire 120gb hard drive (Beyond Micro) to accompany it. Works wonderfully, 3 weeks into it.
I hauled off & bought a Sony DRX-500ULX to burn DVDs with and NOW I'M TOTALLY FREAKING OUT.
The Vaio comes with a 15gb hard drive partitioned into two, C & D drive. Sonic MyDVD, in the software that comes with the burner, apparently requires 10gb of free hard drive space to function. I installed it on C, and it froze upon opening. Re-installed it on D, same thing. I called Sony Tech support & they said it needs to be on C, & the 10gb needs to be ON THE SAME DRIVE. (i only have 2.66gb free) "Send it back." She said. And it was very quiet.
Did I pull a full-on Barney?
Is this true?
Is there a smaller program?
Thank you very much for any help you can offer,
dan
The tech support I found on Sony was so-so. I don't know if you need to
return your dvd burner. I also have a Sony Vaio and I did have enough space to run it (25gb) but I have around 23gb to process vacation video. I am also running Premire 6.5 as my editing software. You should be able
to install it to your new h.d. without any problems -
Thanks man,
Yeah, I did try installing it on the external hard drive-- twice. It installed, then everything froze during restart. I think the software is wacky.
The Sony tech gave me absolutely NO suggestions, no direction, nothing. Very short, very rude. I actually told her she sounded like she was under the gun, like she wasn't telling me something. Now that I think about it, it was pretty erie.
ANYHOO, I'm glad to hear your burner works, maybe I'll try different software....
something small
HP vs Sony Vaio
By Tom81 in forum ComputerReplies: 13Last Post: 6th Jul 2011, 23:29 -
Service manual for Sony VAIO desktop PC
By PartingShot in forum ComputerReplies: 1Last Post: 19th Apr 2011, 17:10 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 18:45 -
sony vaio desktop
By deadman1972 in forum Newbie / General discussionsReplies: 41Last Post: 21st Apr 2009, 01:33 -
sony vaio pcg 8n2m laptop
By Mr anderson in forum ComputerReplies: 5Last Post: 7th Nov 2007, 15:25
Is this possible?
