Sorry if this is in the wrong place, I thought it was kind of fitting.
I've been capturing home videos to make into CVD's, but I wanted to edit them first. I also wanted an uncut version of each video in divX on one cdr just in case I ever regreted cutting something out. I've never encoded divx before, and I used DivX doctor. The picture quality was great, but during motion scenes, straight lines turned into curvy waves. What's up with that?
You can also find more info here ( www.lukesvideo.com ). Read the interlacing and telecine sections.
Impossible to see the future is. The Dark Side clouds everything... -
Yep, it is interlacing. To get rid of that add a deinterlace filter in virualdub, in virtualdub under video->filters->add->smart deinterlace. And as the other says read more about interlacing and deinterlacing on lukesvideo and http://www.100fps.com
Should deinterlace VHS captured material ?
By macmithos in forum MacReplies: 17Last Post: 5th Jan 2016, 10:56 -
How to Create FLV files from AVI material ( Xvid / Divx )?
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 19th Jan 2010, 09:31 -
adding subtitles to AVI (xvid or divx) WITHOUT re-compressing
By truthlesshero in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 10:43 -
Transfer material Samsung camcorder-->PC problem
By Shagis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 25th May 2008, 02:37 -
dvdauthor authoring problem (combing 16:9 and 4:3 material)
By ecc in forum Authoring (DVD)Replies: 4Last Post: 5th Jul 2007, 20:14
