I have video in mp2 format it is 50min and 2.4GB. What is the best way or software to compress for SVCD burn? I am a newbie.
Video is not compressed in mp2 (mpeg-1 layer II)
They are MPEG-2.
Use TMPGEnc, use a SVCD Template. PAL if your in a PAL country. NTSC if your in a NTSC. Film is your source is 23.976fps(add pulldown flag later), or just regular NTSC if your source is 29.97fps. -
Not all videos are in MPEG-2 either. There are many different compressors and decompressors.
I have TMPGEnc and have used it to merge and cut my videos with ease. My ATI captures the files as .mp2 but these are huge files. When I try to convert with TMGEnc so the file will be sized for a burn it gives an error and does not recognize my files? I tried the suggestions in other posts, Im sure its somethin simple?
.mp2 is an audio file. are you trying to load it as video?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
When I capture TV on my ATI Radeon 9800 is saves original files as .vcr
When you right click on .vcr the option is save as MPEG-2 and I say yes.
Then wherever i saved file it shows up as .mp2 it plays fine video and audio in all types of players but if I want to compress for SVCD burn the TMPGEnc does not recognize? -
Sounds like ATI is converting it to MPEG2, but naming it the non-standard way ".mp2". To fix this part, all you have to do is rename the extension in Explorer to ".mpg".
If TMPGEnc is not accepting it, that doesn't surprise me: it doesn't natively accept MPEG2 files. You either have to Frameserve from another program that DOES accept MPEG2 (e.g. DVD2AVI) or add the acceptable MPEG2 codec (Sony, Ligos, Mainconcept--these only for TMPGEnc v 2.57 and above).
HTH,
Scott -
Thanks, the DVD2AVI did the trick. Everything is coming together real nice now. This is a great forum.
How to compress videofiles?
By BigDrago in forum Video ConversionReplies: 11Last Post: 9th Aug 2011, 13:00 -
How to compress files?
By Takeonelastbreath in forum Newbie / General discussionsReplies: 7Last Post: 20th Sep 2010, 12:42 -
Do I need to Compress the Data?
By Seanna in forum MacReplies: 10Last Post: 17th Mar 2010, 14:32 -
compress video
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2009, 04:43 -
Can i compress a
By YOURCONNEXX in forum Video ConversionReplies: 4Last Post: 9th Dec 2007, 13:03
