  1. i've captured some files with imovie that are in letterbox widescreen. i want to convert them to DVD-standard mpeg-2, but crop out the black areas of the picture at the top and bottom so my encoding only concentrates on the actual picture of the image.
    i did have a play around with ffmpegx, but whatever values i put into the "crop" part didn't seem to have any effect.
    here's my original image (at exact pixel size):
    can anybody help?
    thanks
    -Mark[/img]
    Swim with me
    And we'll escape
    All the trouble
    Of the present age
    Finally free
  2. Currently the ffmpegX crop control only work for ffmpeg and mencoder codecs (no mpeg2enc crop). You can however easily crop your source .mov in Quicktime player by using the "Mask" function. Take a screenshot of the movie and use Photoshop or Graphic Converter to make the video part black, and the area you want to crop white, and save it as PICT image. Then use "Mask" to load the mask image, and save as.. the resulting movie with dependencies. Finally encode it to mpeg-2.
  3. thanks very much, will give it a try. the only bad thing is about this is having to export to another DV file which takes awhile. oh well, i guess it's a solution..
    Swim with me
    And we'll escape
    All the trouble
    Of the present age
    Finally free
  4. Originally Posted by geek rock
    No need to export. Saving with dependancies takes 0.5 seconds.
  5. Anonymous
    Guest
    I'm having the same problem. I was capturing a VHS tape and saved it as MPEG-2 file (DVD quality). Unfortunateley I have a few pixels of "mess" on the bottom of the video-file.
    Isn't there a simple way to "cut" that bottom part without converting the
    video in another format (and losing quality).
    Any help is very much appreciated!
    Wursti
  6. Use this method. It doesn't involve any reencoding or converting to another format.
